Norstat now offers a category 4 Light Curtain that provides competitive performance and innovative features all in a robust, compact housing.
The EOS4 features a compact aluminum housing measuring only 30 x 28 mm that can detect a finger, hand or whole body as well as utilize a multibeam function for access control. The EOS4 has easy connection and installation thanks to M12 connectors, come standard with 2 safety PNP static outputs as well as hardware configuration which eliminates programing.
The EOS4 Light Curtain line includes models with integrated safety functions including, self-monitoring of static outputs, control of external contactors as well as an automatic/manual selectable restart function. Primary/Secondary models are also available for cascade connections of two or more units. The EOS4 is also available in Vibration Resistant models, Explosion Proof ATEX model or with a watertight, Food Graded, IP 69K Certified enclosure making these light curtains ideal for robotic cells, textile, assembly lines, food processing as well as cutting, punching or pressing applications.
The EOS4 conforms to safety levels SIL3, SILCL3, PL e and Category 4, has an operating temperature range of -10° C to +55° C and carries a Protection rating of IP 65/IP 67 at the same time while also being highly resistant to infiltration by dust and liquids.
Norstat
www.norstat.com
You may also like:
Filed Under: Light curtains
