Pillow blocks with bearings have self-aligning properties and are easy to mount and dismount. They are widely used in various types of machinery, especially in agricultural, textile, metallurgical, mining, and various conveying applications. With a self-aligning structure, they can compensate for alignment errors or flexing of the shaft. According to the needs of clients, the internal set-screw hole of the bearing can be specially heat-treated to enlarge the set-screw’s tightening torque and will help prevent the inner ring from cracking. A plastic cup for grease fitting can be supplied only if the customers mention it in the contract.
Plummer blocks(pillow blocks with split housings) such as SN500 series, SN600 series, SN200 series, SN300 series are also supplied. Please consult VISTA for availability.
CBCC
www.bearing.com.cn
Filed Under: Bearing Tips
