CEJN creates open-standard for WEO
By Michelle DiFrangia | April 28, 2016
CEJN_WEOMany global companies are “plugging in” to hydraulic systems by using CEJN WEO Plug-In fittings, with the innovative click-to-connect feature. The market for WEO is comprehensive as the product is found everywhere from large forestry machines to fork-lifts. The product is known for reducing installation time dramatically and is often used when space during assembling is a critical issue. It is also leak-free and extends hose life by eliminating hose twist. Due to all these benefits and more, WEO has been chosen by many large customers, which has led to a higher demand for WEO availability on the aftermarket. By releasing the male part (nipple) as an open standard, CEJN sees a future where WEO is even more accessible worldwide, thanks to more manufacturers and shorter distribution chains.
Co-operation is now available from CEJN to customers who wish to receive support in their manufacturing process of nipples. Just a registration and an agreement that the CEJN specifications are followed makes it a simple process to become a WEO nipple manufacturer.
As always when an open standard is created, it is to protect the reputation of WEO and to ensure that the end user gets interchangeability, highest quality, performance and safety. The CEJN service will consist of specifications such as drawings and process parameters to reach specified performance and quality levels. If changes are made on those parameters, CEJN will update the registered manufacturers.
By creating this open standard, CEJN has looked at what will be most beneficial for manufacturers, OEMs and the end users. In the future CEJN will focus on cost effective deliveries of the WEO Cartridge, the core in plug-in technology, from a fully automated and quality assured production line running around the clock in the CEJN facility.
CEJN
www.cejn.com/weo
The post CEJN creates open-standard for WEO appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
Tagged With: cejn
single-cover-small-232x300
Midland Metal launches updated 2017 catalog
nfpa
NFPA hosting Chicago Regional Meeting on December 7
RYCO Hydraulics debuts 24-7 program in Houston
NAHAD’s charitable water cause surpasses $10,000 mark
