Waukesha Bearings applies ceramic and cermet (ceramic-metallic composite) materials to thrust and journal bearing designs to extend bearing capabilities in applications where traditional materials and polymers fall short. The extremely hard surfaces of ceramic/cermet bearings can handle corrosive materials, contaminated lubricant and temperatures beyond the limits of polymers and traditional materials.
Ceramic/cermet bearings:
Retain their mechanical properties and load carrying capacity over a wide range of temperatures, including extremely cold and hot environments
Are compatible with very thin hydrodynamic films and low-viscosity lubricants
Are resistant to most chemicals, including hydrogen sulphide and ammonia
In addition, ceramic/cermet surfaces are harder than common abrasives, such as sand, and will crush abrasive debris in the lubricant, preventing bearing damage.
Of note, the use of ceramic/cermet requires deliberate material selection for both the rotating and stationary surfaces, especially when abrasives are present or films are extremely thin.
Waukesha Bearings
www.waukbearing.com
The post Ceramic bearing technology appeared first on Bearing Tips.
Filed Under: Bearing Tips
