Ceramic hybrid radial bearing line
By Mike Santora | February 1, 2017
Boca-ceramic-hybrid-imageThe Boca Bearing Company has announced a new ceramic hybrid radial bearing line for Radio Control applications, the Boca Bearing’s RC Go series. With the introduction of the new RC Go series, Boca Bearing Company hopes to introduce a new generation of RC racers and enthusiasts to ceramic bearing technology.
The Boca Bearing’s RC Go bearings are ceramic hybrid radial bearings. Ceramic Hybrid bearings refers to bearings that have metal races and ceramic rolling elements. In the case of the RC Go series, the inner and outer races are a hardened chrome steel, suitable for the rough wear and tear of RC racing. The rolling elements are Ceramic Silicon Nitride (Si3N4) spheres. Ceramic has a glasslike surface finish, is harder and lighter than steel, is will not corrode. Ceramic hybrid bearings are able to reach higher rpms and maintain lower operating temperatures.
The other unique characteristics of the RC Go Series is that on side of the bearing has a rubber seal, while the other side has a metal shield. By installing the bearing so the rubber seal faces out, the bearing is better protected from dirt and debris from dirty off-road environments. For cleaner operating conditions, the rubber seal can be taken off to further reduce friction and the metal shielded side can be installed facing outward. By having one or no rubber seals, the friction that is normally associated with a rubber-sealed bearings is reduced or eliminated.
Boca Bearings
www.bocabearings.com
The post Ceramic hybrid radial bearing line appeared first on Bearing Tips.
Filed Under: Bearing Tips
Tagged With: bocabearings
  • Tech Toolbox: Designing for cleanrooms
