Phoenix Contact continues the expansion of its Cable Entry System (CES) product line with the addition of the CES Multigates. These space-saving, metal-reinforced cable entry plates have double-membrane sealing, which ensures a high degree of protection (IP66/67).
The CES Multigates can handle up to 37 cables with an outside dimension of 5 mm up to 60 mm. The CES Multigates offer a low-cost panel feed-through solution, especially where a panel-mounted connector is not preferred.
Additional features of the CES Multigates include a UL 94 V0 flame rating and oil-resistance. The product has a temperature rating of -40°C to +100°C. To help make installation easier, Phoenix Contact has also released stainless steel module mounting plates for the CES products.
Pheonix Contact
phoenixcontact.com
The post CES Multigates handle up to 37 cables appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips
