Cicoil Develops High Performance Cat 5e Cable
By Design World Staff | June 30, 2009
Valencia, CA – Cicoil announces the introduction of Cat 5e cable featuring a highly flexible flat profile and an exclusive, extruded silicone encapsulation. While meeting or exceeding all electrical and signal requirements for the Cat 5e standard, Cicoil‚’s version excels with physical and environmental attributes. Temperature rating is a broad -65‚°C to +260‚°C range and is flame resistant. They are submersible, with excellent resistance to steam, salt water and de-ionized water; and are further resistant to chemicals, acid, oils, alcohol, and ozone.
Cicoil‚’s Cat 5e cables were created to meet the increased demand of professionals who need a rugged, reliable, portable and flexible network cable solution. They excel in the field where environmental contaminants can damage or degrade common cables.
In repeated flexing applications, Cicoil Cat 5e cable features a repeated bend radius of just 0.9 inch, and a cycle life exceeding 10,000,000 repetitive flexing. It also features a Durometer Rating of Shore A, 65. In addition, they are approved by NASA for space flight, and exceed outgassing specifications for vacuum and space use. They are rated for radiation exposure to 10-7 Roentgens.
Cicoil
www.cicoil.com
Filed Under: Cables + cable management, CONNECTIVITY • fieldbuses • networks • gateways, Motion control • motor controls
