Cicoil’s New StripMount Cable
By Design World Staff | July 25, 2008
Valencia, CA: Cicoil‚’s new StripMount‚â„¢ design makes it quick and easy to mount cables to any surface. The patent-pending design allows for holes to be easily punched or drilled through the StripMount‚â„¢ cable reinforcement at whatever intervals you need. Use any fasteners to attach the cable to any surface.
StripMount‚â„¢ is a fiberglass-reinforced ribbon that customers can add to any Cicoil cable. It is encapsulated in Cicoil’s exclusive silicone jacketing and provides more than 250 lbs. holding force. Customers simply add the StripMount‚â„¢ option as they specify the wire conductors that make up their cable. Using StripMount‚â„¢ equipped cables eliminates the need for costly conduit and cable tie hardware. It streamlines cable installation. Cables with StripMount‚â„¢ may be installed using self-tapping screws, rivets, or the wide variety of quick-operating metal or plastic panel fasteners available. In addition, because Cicoil cables are flat, multiple cables can be stacked and attached to any surface.
Download a complete StripMount‚â„¢ data sheet at the company’s web site–www.cicoil.com
Filed Under: Cables + cable management, ELECTRONICS • ELECTRICAL
