Cicoil’s StripMount™ Awarded U.S. Patent
By Design World Staff | June 29, 2010
Valencia, CA – Cicoil announced that its innovative StripMount™ cable mounting feature option has been awarded U.S. Patent No. 7,678,998. Cicoil’s StripMount™ design makes it quick and easy to mount cables to any surface without the need for cable carriers, conduit, or other cable management hardware. Listed as inventors are Howard Lind and John Palahnuk.
Cicoil-StripMount-US-Patent
StripMount™ is a fiberglass-reinforced ribbon that customers can add to any Cicoil flat cable. It is encapsulated in Cicoil’s exclusive clear silicone jacketing, and it provides more than 250 lbs. holding force. Customers simply add the StripMount™ option as they specify the wire conductors that make up their cable. Using StripMount™ equipped cables eliminates the need for bulky, time-consuming cable carrier, conduit and cable tie hardware, greatly simplifying cable design and installation. Cables with StripMount™ may be installed using screws, rivets, or with virtually any fastener available, making it quick and easy to securely attach your flat cable to any surface. In addition, multiple Cicoil flat cables can easily be stacked and attached to any surface.
The StripMount option is available with most cables from Cicoil’s online catalog, or with any custom flat cable.
Cicoil
www.cicoil.com
Filed Under: Cables + cable management, Electronics • electrical
molex-premo-flex
