CICOIL has a new Motion Series Cable line. Shielded power and signal wires come in one cable for 1, 2, or 3 servo axes. Wires are available for 1, 2 and 3KW servo motors. High flex cables give over 10 million life cycles under the most demanding conditions, making them ideal for linear motion and tight-space applications.
All wires are fully-encapsulated in glass-clear silicone, in a solid, one-piece construction. Cicoli cables perform in temperatures from -65° C to 260° C and during exposure to water, steam, and chemicals. They are also ideal for vacuum or clean room environ- ments.
Standard cables are in stock for immediate delivery. Custom designs, including cable assemblies with standard connectors, are also available with minimum lead times.
Call 661-295-1295 or email to discuss your application, or to place an order.
Cicoil 24960 Avenue Tibbitts
Valencia, CA 91355
Tel: 661-295-1295
Web: www.cicoil.com
:: Design World ::
Filed Under: Factory automation, Cables + cable management, Motion control • motor controls
