The Sentinel C28-DP is a compact leak test instrument built for maximum performance utilizing Differential Pressure Decay technology. Designed by Cincinnati Test Systems, the instrument utilizes advanced algorithms to produce fast and accurate results required by the most demanding customers. The C28 has earned a top notch name in the marketplace and now CTS is pleased to announce that this high caliber instrument has received expanded flexibility by adding differential pressure testing to its platform (both hardware and software).
The C28-DP is designed utilizing two transducers; an absolute transducer on one 24-bit analog to digital circuit to measure test pressure and a differential pressure transducer on a second A-D circuit to measure high resolution pressure changes during the leak test. The high resolution measurement is converted by the instrument to a volumetric leak rate from the automatic calibration cycle. CTS utilizes a silicone based strain gage DP transducer to reduce inherent drift and accuracy issues found with capacitive DP transducers.
The Sentinel C28-DP instrument is designed to be operator friendly and it can handle a wide range of test types while offering outstanding data tracking capability. The C28-DP comes in a compact package that provides: differential pressure decay, pressure decay, drop, rate of change, and occlusion test types; vivid, state-of-the-art color graphic screen for easy navigation and viewing; on-screen accept criteria is displayed for positive operator feedback; language neutral keypad and multi-language software; automatic part setup for easy programming of up to 32 part programs; auto calibration ensuring accurate results and easy operation; quick test for reducing test time and analyzing test results in real time; flexible communication formats — Ethernet, and RS-232; last 5000 tests stored in on-board memory.
Cincinnati Test Systems, Inc.
www.cincinnati-test.com
Filed Under: ENGINEERING SOFTWARE, Test & Measurement Tips
