Automotive Relays range from low current up to 80 A with voltage
ranging from 6 Vdc to 72 Vdc. PC pin and quick-connect mounting methods offer multiple choices for the design engineer, along with the option of mounting tabs in plastic and metal. Automotive relays can be found in just about every car, truck, tractor, bus, golf carts and more. Used to
enable a low amperage circuit to switch on and off a higher amperage circuit like headlights, relays are also used to switch multiple things at the same time using one output. A single output connected to multiple relays allow ope
CIT Relay & Switch, 14680 James Road, Rogers, MN 55374, 763-535-2339, Fax: 763-535-2194, Email: [email protected], www.citrelay.com
Filed Under: Relays, MOTION CONTROL
