C&K Components has expanded its line of switch products for smoke detectors in support of the new European EN-14604 standard.
According to the new regulation, all smoke detectors sold in the European Union must include the CE marking and comply with EN-14604 standards, which require all smoke detectors to be equipped with a test button.
The KMT0 Series tactile switch from C&K is the most compact switch on the market that meets the requirements for the EN-14604 test button. Moreover, the IP68-rated switchs ability to withstand gas corrosion tests makes it the ideal solution for harsh environment applications typical with many smoke detector installations. The KMT0 Series features a low-profile of 0.65mm with integrated actuator and an operating life of up to one million cycles. An ultra-low current version is also available, which extends battery lifetime.
In addition, C&Ks KSA/KSC Series sealed tactile switches feature customizable actuation and button height. The top- or side-actuated KSA/KSC Series switches are surface mountable and deliver a specific actuator with a groove for button clipping and compatibility. The IP67-sealed KSA/KSC Series switches have a unique design that provides simple integration with an operating life up to one million cycles. The combination of IP67 sealing and gold plating offer a high resistance level against ingressions and corrosion agents which leads to reliability and service life required by fire detection applications.
Another switch product that meets the requirements for smoke/fire detectors and carbon monoxide detectors is the KSE Series of cost-effective, low-profile tactile switches. These momentary-action tactile switches combine rugged IP67-rated sealing, reliability and a long operating life with an optimized, economical design.
Ideal for identifying the location of smoke detectors on the premises, the miniature RTE Series of low-profile rotary DIP switches are available in surface mount and through-hole models. The RTE Series DIP switches feature SPDT, SP3T and SP4T rotary functions, as well as rotary binary-decimal and hexa-decimal coding. With a robust stainless steel cover, the RTE Series has an operating life of up to 20,000 actuations.
C&K Components uses innovative technologies to develop switches that answer current and future application needs. The expansion of our product offering makes C&K a one-stop-switch-shop for manufacturers of devices such as smoke detectors, said Eric Grange, Product Manager at C&K Components.
C&K Components
www.ck-components.com
Filed Under: TECHNOLOGIES + PRODUCTS, Actuators, Batteries, Electronics • electrical, Switches
