SCOTTSDALE, Ariz. ‚– NKK Switches announces the availability of the CKM Series of high security keylock switches. The CKM keylock switches are ideal for industrial control equipment, computer peripherals, and instrumentation and sensor equipment.
The CKM Series ON-OFF-ON switch models with tubular keys feature a push-and-lock mechanism which indicates to the user when the switch position has been changed. They also feature a vertically rotating switching mechanism and self-cleaning sliding contacts to ensure that they have a long operating life, smooth operation and guaranteed circuit contact.
Incorporating an antistatic insulating material, the CKM series is able to withstand 15 kilovolts of electrostatic discharge. Their Dielectric Strength rating is 1,500 volts between contacts and case for a one minute minimum. In addition, the terminals are epoxy sealed to prevent the entry of flux and other contaminants.
A 16mm double flatted bushing ensures that the CKM series fits securely in panel mounts. The operating temperature range is -25?C through 70?C and the switches are capable of withstanding 90-95 percent humidity for up to 240 hours. The series is rated 3A @ 250V AC.
These switches are available in single pole configuration and both two-position and three-position models. The two-position models feature a 90 degree angle of throw and the three-position models a 45 degree angle of throw. Circuit options are ON-ON or ON-OFF-ON.
Keys are removable in one or two positions depending on the circuit selection and flat or tubular key styles are available, with the flat key being reversible for easier setting. Keys are supplied with randomly assigned key numbers and one key is provided with each switch. Additional keys can be ordered by specifying the key number engraved on the switch.
Filed Under: Electronics • electrical, Switches
