Clean-In-Place Pressure Transducer Features Flush Diaphragm
By atesmeh | September 9, 2010
Stellar’s Series FT31XX clean-in-place (CIP) pressure transmitters are designed to meet the demands of the wet and hostile environments of industrial process applications that use a flush diaphragm and Tri-Clover flange clamps. These pressure transmitters incorporate a one-piece, non-welded diaphragm for reliable performance and long life in process applications such as homogenizers, heat exchangers, filters, pasteurizers, emulsifiers, surge tanks, and biopharmaceutical mixers. In addition, the FT31XX design does not use an oil fill, thus eliminating the possibility of process contamination. Users can select from analog outputs of 4-20 mA, numerous voltage outputs, as well as digital outputs ranging from RS232 and RS485 to CANbus. The FT31XX offers isolated voltage output as standard for voltage output units. All internal electronics are fully potted for shock and vibration resistance and thermal stability. Pressure ranges extend from 5 psig to 10,000 psig. This unit delivers 0.25 percent static accuracy and is shipped with a standard 15 point calibration record traceable to NIST.
Stellar Technology, Inc.
716-250-1900, www.stellartech.com
