“Click-Clack” mounting system means quick installation without tools
By Heather Hall | July 13, 2021
Norstat now offers a signal device mounting system that incorporates a base which allows for quick installation or removal with just a twist of the wrist.
The “Click-Clack” mounting base allows for quick and easy installation of stack lights, beacons or buzzers due to its innovative and functional new mounting method. The “Click-Clack” system is a unique approach that simplifies the mounting or removal of a signal device by simply twisting the locking base unit. This system is ideal for reducing machinery obstruction and allowing for easier shipping or for reducing maintenance and repair time. The twisting motion assures a solid lock without the need for tools.
The “Click-Clack” mounting system is available for most 70 mm modular stack light and signal device bases but is also available for smaller signal units. It can be mounted directly to a machine or to a bracket for 90° fixing.
Norstat
www.norstat.com
You may also like:
  • 3D streaming cameras from SICK
  • Fixed and floating header coaxial connectors for automative cameras
  • Batteries and DIN-rail battery chargers for uninterruptible power supplies (UPSs)
  • Optocoupler modules in interface electronics
  • DIN rail-mounted industrial power-supply fundamentals
  • Optimizing Lubrication Maintenance for Overrunning Clutches
Filed Under: Connectors (electrical) • crimp technologies, Lights • signal lamps • indicators
Tagged With: norstat
molex-versablade-300x300
Heilind Electronics now offering Molex VersaBlade Wire-to-Wire Connector System
bel-stewart-m12xcode-connector
Stewart Connector M12 X-Code PCB mount connectors
Heilind-electronics-product-image
Heilind Electronics now offering Molex PowerPlane BusBar Power Connectors
Harting Technology Group heads for a climate-neutral future with record investment
