Higher amperage relay output modules and an 8-point input simulator module are now available from AutomationDirect for the CLICK series stackable micro brick PLCs.
The CLICK C0-04TRS-10 ($54.00) is a 4-point, 10A per point, isolated relay output module with four Form A (SPST) relays and 4 isolated commons. Operating voltage range is 6-24 VDC / 6-240 VAC. The C0-08TR-3 ($49.00) is an 8-point, 3A per point, relay output module with eight Form A (SPST) relays and 4 isolated commons. Operating voltage range is 6-27 VDC / 6-240 VAC.
Priced at $40.00, the C0-08SIM input simulator module provides 8 toggle switches to simulate input devices, 8 logic side green status LED indicators and an LED power indicator.
AutomationDirect CLICK PLC units, starting at $69.00, are low-cost, brick/stackable PLCs with the processing, memory, communication and I/O interface needed in an automated control system.
AutomationDirect
www.automationdirect.com/click-plc
Filed Under: I/O modules
