Rittal’s Therm 6.0 enclosure climate control specification software is available for download at the company’s website. It can help you select the type and size of climate control solution that best suits your needs. The latest version of the product offers improved navigation and a more intuitive design.
Rittal’s Therm 6.0 sizing and specification software ensures that you select the right climate control solution to optimize the performance of your industrial enclosure applications.
You enter data relevant to your application, complete some calculations and the software determines the cooling capacity required to provide the best solution based on the information provided. The product considers size and location of the enclosure, ambient temperature, and maximum allowable internal heat loss of many commonly installed electrical components, integrated air humidity calculation, variables encountered with bayed enclosure suites, and elevation above sea level are some of the in-depth criteria that Therm 6.0 uses to help you find the ideal climate control. You can output calculation results as HTML or XML documents and you can import prior calculations from Therm 5.14.
Rittal Corporation
www.rittal-corp.com
Filed Under: Electronics • electrical, Software
