These unique two-piece rigid clamping couplings come with an undersized ID. Allows you room to re-bore the ID without damaging the clamp screws. Pilot bore can be opened to the nominal ID reflected in the part number.
• These unique two-piece rigid clamping couplings come with an undersized ID
• Allows you room to re-bore the ID without damaging the clamp screws
• The pilot bore can be opened safely to the nominal ID reflected in the part number
Climax Metal
www.climaxmetal.com/index.html
Filed Under: Coupling Tips
