Climax C801 Single Nut Locking assembly is designed to provide a high-capacity mechanical interference fit between components. The C801 locking assembly eliminates the need for keyways or cumbersome fits. It provides zero backlash and can be installed quickly due to the simple single-nut tightening design. C801s are suitable for situations with spatial constraints and are supplied zinc plated for corrosion protection.
The C801 Series is available from stock in a full range of inch and metric sizes. To help you find the correct interchange, we have prepared a Functional Cross Reference Guide.
Climax Metal
www.climaxmetal.com/blog
Filed Under: Coupling Tips
