For applications that require better access or enhanced cleanliness, Clippard pinch valves are also available with a convenient panel mount option. Panel-mounted pinch valves provide all the same benefits as Clippard’s standard pinch valves, along with seamless integration and easy accessibility. Compared to standard manifold-mounted pinch valves, panel mounting offers simplified installation, a cleaner appearance, and reduced contamination risk.
As with all Clippard pinch valves, panel-mounted pinch valves feature an unobstructed flow path with zero dead volume — only the inside of the tubing contacts the fluid. Features include:
- Unobstructed flow path
- Each valve comes with 12” (30 cm) of silicone tubing pre-installed
- Tubing is easily replaceable
- Available in electronic or pneumatic versions
- High cycle life
Clippard
clippard.com
Filed Under: Uncategorized
