    • Subscribe!
Clippard High Flow Proportional Electronic Valves
By Clippard Instrument Laboratory | October 9, 2017
Clippard’s newest DVP series proportional solenoid valves are precision-built 2-way control valves, utilizing a unique, patented valving principle. This powerful series was designed as the next generation of the well-known and trusted original EV line of Clippard “Mouse” valves. With a life of over a billion cycles, a solid, compact design, and extremely high flow rates, these valves are suitable for many applications across numerous industries.
The DVP series valve provides air or gas flow control, and varies the output flow based on the current input to the solenoid. The consistent gain of this valve provides a high degree of control. Controllability and overall value are the main features of the DVP series. The valve may be controlled using DC current, open or closed-loop control, and even PWM (Pulse Width Modulation) to cover a large range of applications:
• Industry standard for leak-free operation
• Over 1,000,000,000 cycles
• Extremely low hysteresis
• Fast response time
• Large flows in small, sleek design
• Low heat rise/low power
• Robust stainless steel “Spider” flat armature spring
For more information about these valves or any of Clippard’s 5,000 other pneumatic
products or services, call 513-521-4261 or visit www.clippard.com.
    • Subscribe!
