    • Subscribe!
Cognex Connect™ Suite of Communication Capabilities
By Design World Staff | June 3, 2009
Cognex Corporation (NASDAQ: CGNX) announces Cognex Connect‚â„¢, the most comprehensive suite of communications capabilities ever offered in a vision system. Cognex Connect enables out-of-the-box connectivity between Cognex In-Sight‚® vision systems and virtually any major PLC, robot, HMI and Fieldbus system commonly used in factory automation. A simple point and click configuration interface makes it easy to control multiple vision systems from any network PC, and allows users to easily transfer data and images to an enterprise file server or display them in the user‚’s own operator interface.
The standard Cognex Connect suite of communication capabilities includes pre-configured drivers, ready-to-use templates and sample code to accelerate system set-up and ensure smooth communication with factory automation robots and controllers. Cognex Connect also provides an array of visualization options for integrating inspection images from In-Sight into a central operator interface.
Cognex Connect delivers built-in support for the following controls and communications:
‚· PLC – Cognex Connect supports open standard industrial Ethernet communications protocols such as MC Protocol, EtherNet/IP and PROFINET for trouble free connection to a wide range of PLCs including Mitsubishi, Rockwell and Siemens.
‚· PC or HMI – Cognex Connect supports OPC server, Active X display controls, and standard TCP/IP Ethernet protocols.
‚· Robots – Pre-configured drivers, ready-to-use templates and sample code are available for robots by ABB, Denso, Fanuc, Kawasaki, Kuka, Motoman and Staubli. Communication with robots by Mitsubishi, Adept, Epson and many other manufacturers is also supported.
‚· Fieldbus – Cognex Connect supports all established standards, including CCLink, DeviceNet, and PROFIBUS.
Cognex
www.cognex.com/connect
Filed Under: Factory automation, Electronics • electrical, HMIs • operator interfaces • monitors, Networks • connectivity • fieldbuses, PLCs + PACs, Vision • machine vision • cameras + lenses • frame grabbers • optical filters
molex-premo-flex
    • Subscribe!
