Cognex Upgrades Its Powerful Line Of Handheld Barcode Readers
By Stacy Combest | April 25, 2013
Cognex Corporation has upgraded its line of DataMan® 8000 series industrial handheld barcode readers with a major performance boost to both reading robustness and speed. The already powerful handheld readers are now equipped with proprietary Cognex Hotbars™ image-analysis technology for the fastest 1-D barcode reading performance and Cognex 2DMax+ algorithm for unmatched decoding of 2-D printed and DPM matrix codes. The new features also include a rapid dual-focus image acquisition routine which enables the readers to decode a wide range of barcode sizes even faster.
Easily read the most challenging 1-D barcodes
1DMax+ with Hotbars enables the DataMan 8000 series to read the most challenging 1-D barcodes quickly and easily even when those barcodes are damaged, blurred, at extreme perspective, or otherwise challenging.
Customizable settings for 2-D code reading
The DataMan 8000 series now utilizes the powerful 2DMax+ algorithm, which has the fastest decode times and is effective even on codes with perspective distortion, low contrast, or finder and clocking pattern damage. The DataMan 8000 series now allows the user to select the type of code to be read (from easy to extremely challenging). This is especially useful for increasing reading speeds when only printed or high-contrast codes are being read or when facing the most challenging DPM codes that cannot be read with standard settings.
dataman8000
Fast image acquisition and liquid lens settings
The DataMan 8000 series is now equipped with patented auto-exposure algorithms and faster image acquisition and liquid lens performance. The faster imaging means readers can now be used in a dual focus mode, which allows users to increase the depth of field or to read a wide range of barcode sizes, from very large multi-inch barcodes to tiny 5 mil 2-D Data Matrix codes.
The DataMan 8000 series is available in two base models:
DataMan 8500
The DataMan 8500 readers incorporate patented UltraLight technology from Cognex for superior image formation on any code type and surface. UltraLight illumination provides dark field, bright field and diffuse lighting all in one electronically controlled light.
DataMan 8100
The DataMan 8100 includes all of the features of the DataMan 8500 readers as well as bright field illumination. The DataMan 8100 readers are ideal for applications that require superior code reading performance without specialty lighting.
Cognex
www.cognex.com
Filed Under: Vision • machine vision • cameras + lenses • frame grabbers • optical filters • scanners
Tagged With: cognex
