DESCRIPTION
Safety coupling with linear limitation of force. Releasing both compressive and tension once it reaches the calibration force. The setting force can be adjusted by turning the adjuster nut onto the springs and re-engagement is automatic. The possibility of connecting linear motion is also very distant from each other.
No axial play
- Protection in both tension and compression;
- Free rides in tension and compression after release;
- Automatic re-engagement in the exact position of disengagement;
- Simple calibration system of force with “H fee” for an immediate calibration of the equipment;
- Made of steel fully turned with special high mechanical strength;
- No maintenance for high reliability in the time.
- Shaft-mounted gearboxes;
- Puck handling and eccentric;
- Transactions structured for pushers and slides;
- Systems of the crank mechanism.
ComInTec
www.comintec.com
Filed Under: Coupling Tips
