DSS/F/SG/PR-V – backlash free ball model for gearboxes (input shaft):
Balls solution, torsional backlash free, maintenance free
Instant disengagement between the driver and the driven component when the calibration torque is exceeded
Available with 360° individual re-engagement
Solution complete with zinc-plated STEEL connection flange for IEC and NEMA motors
IP67 level of protection from external agents
Integrated inductive sensor for monitoring overloads
Maximum torque 720 Nm; maximum bore/shaft ø48mm
Available pre-calibrated and ready for use
Anticorrosive surface treatment option for specific requirements
COMINTEC PR-V GEARBOX TORQUE LIMITERS PROTECT YOUR MOST EXPENSIVE SYSTEM COMPONENTS FROM TORQUE OVERLOADS.
MOUNTED BETWEEN THE MOTOR AND THE GEARBOX INSTANTLY DISENGAGES COMPONENTS BEFORE DAMAGE OCCURS.
Applications:
Food & beverage equipment
Wastewater treatment
Packaging equipment
Shredders/Recycling
Construction:
Ball detent style
Housing: Standard Zinc plated steel
Torque Limiter: Machined Steel
Sensor: Inductive proximity integrated
How it works:
Mounts directly to the motor and gearbox
Suited for flange motors and gearbox
No design work required
Technical:
Units are preset to requested torque setting
Torque setting is adjustable and easy to change
Automatic reset after 360° rotation
IP67 rated
ComInTec
Filed Under: Coupling Tips
