Materials: Acetal, Brass, Stainless Steel
Bore Size: 0.125 in. (2mm) – 0.6250 in. (14mm)
Outer Diameter: 0.25 in. (6.3mm) – 0.625 in. (25.41mm)
Length(closed): 1.5 in. (38.1mm) – 10.1 in. (256mm)
Stainless steel telescoping universal joints are offered in a number of sizes and are heat and corrosion-resistant. Telescoping miniature universal joints feature zero backlash and accommodate 1/4 axial motion. Molded universal joints with a molded slide extension or brass slide extension are available in a variety of sizes, shorter or longer lengths are available on special order.
SDP/SI
sdp-si.com/products/Couplings/index.php
Filed Under: Coupling Tips
