    • On the Floor
Compact 3100 Series Pressure Transducer
By Design World Staff | March 12, 2009
Setra Systems, Inc. offers its Compact 3100 Series pressure transducer providing a low cost solution for OEM applications such as Hydraulic Controls, HVAC Systems, Engine Controls, Industrial Process, Off-Highway Equipment, Compressors, and Pumps.
This unit‚’s small footprint, less than 1 inch in diameter, makes it ideal for installations where space is at a premium, and its all stainless steel construction is resistant to corrosive media typically found in industrial process applications.
The 3100 Series employs highly accurate thin film technology and a unique custom designed ASIC offering exceptional performance with accuracy to 0.25% full scale, long-term stability of 0.1%/yr, and thermal stability accurate to within 1.0%/100‚°F over the entire compensated temperature range of -40‚°F to 250‚°F.
Offered in pressure ranges from 100 psi up to 30,000 psi and a wide variety of outputs(0 to 5, 1 to 5, 0.5 to 4.5, 1 to 6 , 0 to 10 VDC, 4 to 20 mA, and 0.5 to 4.5 V ratiometric,), pressure fittings (NPT, UNF, BSP and Metric), and electrical connectors (M12, Packard, Deutsch, DIN43650C and others), this unit can be configured in any number of ways without incurring extra costs associated with customization. In addition, voltage units are available with a dual temperature/pressure output.
www.setra.com
Filed Under: Sensors (pressure), TEST & MEASUREMENT
    • On the Floor
