Compact and Tamper Resistant Monopole Antenna
By Design World Staff | November 10, 2011
The WRT-MON Series monopole antenna is compact and tamper-resistant. It suits applications in wireless vending machines, traffic equipment and power equipment where space is limited and security is important. The antenna requires a proximity ground plane. It installs through a small hole on the product and is anchored by a threaded metal base connected to the coax cable shield. It is available in 2.4 GHz. It’s attached to an 8.5 in. long coax cable with an RP-SMA, SMA or U.FL/MHF-compatible connector on the other end. The RP-SMA and SMA connectors use an RG-174 coax. The U.FL/MHF connector uses a 1.32 mm micro-coax. More connectors, colors and coax length options are available.
WRT-MON Series
Antenna Factor
www.antennafactor.com
Filed Under: Wireless • 5G and more, Connectors (electrical) • crimp technologies
