Compact Barcode Scanner from Pepperl+Fuchs
By Design World Staff | June 27, 2008
TWINSBURG, OH ‚– Pepperl+Fuchs introduces the compact VB6-240 Barcode Scanner. With a footprint of just 22 mm x 30 mm x 40 mm, the VB6-240 is one of the smallest scanners available today. Yet it delivers 0.15mm (6 mil) resolution to read very small labels, and operates at a speed up to 1200 scan/s to increase productivity by up to 30% when compared with competitive scanners.
‚“The VB6-240 delivers efficient and inexpensive barcode scanning. Due to its compact size and high scanning speeds, it is ideal for applications where space is limited and demands are high. High resolution and the built-in ACR (Automatic Code Reconstruction) embedded reconstruction software algorithm enable the VB6 to effectively decode damaged or normally unreadable codes,‚” says Mike Mendicino, Pepperl+Fuchs Product Manager.
Installation and configuration is simple and easy thanks to the unit‚’s compact size and test operating mode with a built-in bargraph display. Test mode is activated by means of a pushbutton on the scanner (an external PC not required), with an LED bargraph that indicates the real-time read percentage.
www.pepperl-fuchs.com
