Compact controller with integrated switch
By Leslie Langnau | May 14, 2019
The Compact-S series is a compact controller with an integrated switch that enables daisy-chain cabling between network stations.
At a width of 37.5 mm including the power supply, the X20CP0420 is compact. The controller achieves cycle times down to 4 ms and is equipped with 128 MB RAM and 256 MB internal flash memory. With Ethernet, USB and RS232, the controller offers plenty of communication options. An optional CAN bus interface is also available. With no fans or batteries, the compact controller is also maintenance free.
X20 I/O modules can be connected directly to the controller and line up seamlessly. The entire system saves space in the control cabinet. Even with its narrow dimensions, the controller has a built-in power supply for itself and the connected I/O modules. There is no need for a separate power supply module.
B&R Industrial Automation Corp.
www.br-automation.com
Filed Under: Controls (board level), MOTION CONTROL
Tagged With: b&r
