Compact Current Sense transformers sense up to 20 A
By Andrew Zistler | January 12, 2016
coilcraftCoilcraft announces its new CST7030 Series of surface mount current sense transformers which measure just 5.2 X 7.0 mm (with a max height of 3.0 mm) and sense up to 20 Amps of current at frequencies between 10 kHz and 1 MHz. Typical applications include load current measurement and control in switching power supplies and overload/short-circuit protection.
The devices are also qualified to AEC-Q200 Grade 1 (-40°C to +125°C) standards, making them ideal for conventional vehicle and xEV (EV, HEV, FCEV) applications such as current measurement in traction motors and battery management systems. They are also well suited for use in 48V vehicle systems.
The CST7030 Series is available with five turns ratios (primary-to-secondary) ranging from 1:20 to 1:150. It offers very low primary DC resistance (0.0015 Ohms) and 500 Vrms, one minute isolation (hipot) between windings. Coilcraft also offers a high-isolation (1,500 Vdc) version with its CU8965-AL Series.
CST7030 Series current sense transformers feature RoHS compliant tin-silver, over tin, over nickel, over phos bronze terminations and have a maximum reflow temperature of 260°C.
Coilcraft
coilcraft.com
Power Electronic Tips
Filed Under: Power Electronic Tips
Tagged With: coilcraft
schurter
Compact power entry module has side flange mounting option
ABSOPULSE
Three-phase power supplies with active PFC handle 5-kW industrial applications
Sager Electronics to carry SL Power’s 300-W single-output power supplies
wuerth catalog
Catalog covers certified components for automotive electronics
