Compact Cylinders Save Space
By Design World Staff | November 14, 2008
In packaging equipment, space is always at a premium. A new line of Vickers‚® and Hydro-Line‚® L-series light duty pneumatic cylinders include rodless, ISO/VDMA, stainless steel, and non-rotating designs for the packaging, machine tool, material handling and food and beverage markets.
The robust, space-efficient configuration makes installation easy. The L-Series rodless cylinders have an industry standard base with a smooth, compact profile. The stainless steel models feature a captive cushion design for increased safety. The non-rotating cylinders feature a compact, twin-rod design.
L-Series cylinders have pressure ratings from 150 psi (rodless) to 250 psi (all other products) and can be supplied with almost limitless stroke lengths. They are suited for high velocity and compact inch-based or metric environments. Custom versions are available with non-standard larger bore sizes, longer stroke lengths and higher operating pressures.
Eaton Hydraulics Business, a segment of the Eaton Fluid Power Group.
www.eaton.com/hydraulics
Filed Under: Packaging, Linear motion • slides, Pneumatic equipment + components
LM76-SPEED DEMON EL300 4x5x300
LM76 SPEED DEMON EL300 for high speed, low friction, smooth linear motion
Stainless steel linear guide rail systems
LWLF2_FAM
IKO’s New LWLF2 Miniature Linear Guides
igus introduces self-lubricating toothed belt axis designed for clean use in food technology
