Compact electronic slide bolt provides electronic access in limited spaces
By Leslie Langnau | September 13, 2018
Southco, Inc., a global leader in engineered access solutions has expanded its line of electronic access control solutions with a compact electronic slide bolt that simplifies the upgrade from mechanical to electromechanical latching. The lightweight EM-05 5 Series Electronic Slide Bolt is suitable for light load applications where space is limited, and the efficient gear motor-driven mechanism can be easily integrated with any control system.
The 5 Series Electronic Slide Bolt features simple push-to-close functionality and offers an upgrade in energy efficiency compared with solenoid solutions, as no power is required to maintain the product’s retracted or extended position. Offering simple installation and retrofit to existing systems, the 5 Series Electronic Slide Bolt is an economical solution for adding electronic access to a variety of limited space applications.
General Manager Steve Spatig adds, “The EM-05 5 Series Electronic Slide Bolt is significantly smaller than our original EM-05 product, allowing the 5 Series to be used in a variety of applications where space is at a premium. The new slide bolt offers reliable access control with its push-to-close, gear motor-driven mechanism, and its energy-efficient design enables system component and operating cost savings.”
Southco
www.southco.com
Filed Under: Fastening + joining, LINEAR MOTION, MOTION CONTROL
Tagged With: Southco
