The RIO-471×0 is an intelligent input and output controller for Ethernet and can communicate with multiple devices including other RIO controllers, PLCs, and Ethernet motion controllers. It contains a fast RISC processor for handling I/O logic and is programmed using an easy-to-use, two-letter command language. A software tool is available for converting standard relay ladder logic into RIO code. The RIO provides numerous analog and digital I/O plus intelligence in a cost-effective, compact package..
Each RIO-47100 unit is self-contained with numerous analog and digital I/O including: 8 analog inputs, 8 analog outputs, 16 optically isolated inputs, 8 high-power isolated outputs and 8 low-power isolated outputs. Multiple RIO-471×0 units can be distributed on an Ethernet network allowing I/O expansion.
Galil Motion Control
www.galil.com
Filed Under: Ethernet — cables • hubs • switches, I/O modules, Motion control • motor controls, Networks • connectivity • fieldbuses
