More Compact Limit Switch Connection Options
By Frank Tobe | April 6, 2017
AutomationDirect has expanded its AEM2G series compact limit switch line to include more electrical connection options. Four electrical connection types are now available for the AEM2G series of compact limit switches. 5-Pin M12 Quick Disconnect (bottom and right exit) and 3m pre-wired pigtail cable (right exit) connection options have been added to the existing 3m pre-wired pigtail cable (bottom exit) connection. The choice of connection types provides more convenient limit switch installation options.
AEM2G series compact limit switches have die cast metal housings that are epoxy resin filled for IP67 rating and are equipped with one normally-open and one normally-closed contact. These compact limit switches have standard U.S. 25mm mounting hole spacing and are available in a variety of actuator types including metal plunger, lever, rod actuator, and spring actuator. Contact types include both snap-action and slow-make/slow-break.
AEM2G series compact limit switches start at $21.00, have a 1-year warranty and are UL and CE approved.
AutomationDirect
www.automationdirect.com/limit-switches
Filed Under: MOTION CONTROL, Switches
Tagged With: automationdirect
