AutomationDirect has expanded its limit switch line to include the AEM2G series compact limit switches. The switches feature 35 mm wide die-cast housings and are equipped with one normally-open and one normally-closed contact; all units include a three-meter cable. The IP67-rated series utilizes standard 25 mm hole spacing and a wide variety of head actuators is available. Almost all actuator styles are available in both snap-action and slow-make/slow-break contact versions.
AutomationDirect
www.automationdirect.com
Filed Under: Switches, ELECTRONICS • ELECTRICAL
