Compact, Negative-Stiffness Vibration Isolator from Minus K Technology
By Editor | February 28, 2013
Minus K Technology has just released a compact, high-capacity, low-frequency negative-stiffness isolator designed to support heavy payloads while reducing low-frequency vibrations. The new CM-1 isolator comes in several capacity ranges to match vibration-sensitive instruments such as SPMs (AFMS, STMs, etc), micro-hardness testers, profilers, interferometers, electron microscopes, or other imaging systems, for weight loads from 50 to 800 lbs.
The CM-1 can deliver a vertical natural frequency of 1/2 Hz or less, which can be achieved over the entire load range. Horizontal natural frequency is load dependent. 1/2 Hz or less can be achieved at or near the nominal load.
As with all Minus K isolators, the CM-1 is completely passive, using no air or electricity. The new isolators can be combined into multi-isolator systems to support heavy payloads while taking up very little room themselves. The CM-1 isolators can be placed on pedestals to bring them to an appropriate height to retrofit existing air tables, enabling existing table top systems to achieve much better isolation.
CM-1-Compact-Large-Capacity-Negative-Stiffness-Vibration-Isolator-1
If needed, the CM-1 isolators can be customized to achieve user-specific needs. For example, different horizontal and vertical frequencies, damping, etc. They can also be made cleanroom and vacuum compatible.
Weight: Approximately 26 lbs.
Dimensions: 7.875″ W x 7.875″ D x 8.5″ H
Minus K® Technology
www.minusk.com
Filed Under: Shocks + vibration control • gas springs
Tagged With: Minus K Technology
