Even though they have an overall housing length of 53 to 61mm, new CARLO GAVAZZI compact ultrasonic sensors provide sensing distances up to 800mm. The M18 housing of UA18CSD Series uses a thermoplastic construction and UA18ESD Series uses stainless steel.
Available in digital or analog output versions, standard connection options for the sensors include either a two meter PVC cable or M12 connector. All of the sensors in both series are IP67 rated, have cULus UL508 approval and can be operated with 10 to 30VDC.
The sensor target applications in a variety of markets, including wood, material handling, food & beverage, HVAC, packaging, plastic & rubber, agriculture, glass & ceramics and automotive.
For more information are various configurations, click here.
Filed Under: Sensor Tips
