WAGO’s compact Power-over-Ethernet (PoE) expands its line of industrial-grade Ethernet switches. Just two inches wide and four inches tall, the 852-1411/000-001 PoE switch is ideal for all applications with limited space.
The wide voltage input of 24 VDC to 57 VDC, makes the 852-1411/000-001 switch a fantastic option for all PoE applications. The switch supports both PoE operation modes A and B, with all of the ports supporting 10/100/1000 Mbits/s.
This new ECO (economy) PoE+ switch is unmanaged, supplies 30 watts of power per PoE port and has an operating temperature of -10 ⁰C to +60 ⁰C. It eliminates the need to run both an Ethernet cable and power cables to end devices, ultimately reducing cost.
WAGO
www.wago.com/us/switches/industrial-unmanaged-eco-switch/p/852-1411_000-001
Filed Under: IoT • IIoT • internet of things • Industry 4.0, Networks • connectivity • fieldbuses
