Compact Precision Torque Limiters from R+W America
By Leslie Langnau | March 29, 2010
Based on a compact and simple design, the ESL series torque limiters from R+W offer accurate performance at a reasonable cost. Unlike traditional ball-detent torque limiters, the ESL spring loads two series of ball bearings against one another to create a rolling effect at overload.
R-and-W-America-ESL-torque-limiter-
The rolling effect reduces wear and at the same time lets the clutching interface serve as the bearing support during overload disengagements, saving space and cost. This torque limiter uses a specially developed “digressive spring characteristic,” so sensitivity to overload and torque disengagement accuracy are not compromised. Disengagement takes place within 3 milliseconds of overload, and at a value within +/-5% of the disengagement torque setting. The basic design mounts with a keyway and set screw; customized mounting attachments are also available. Technical specifications, solid models, and video are available at:
R+W America
http://www.rw-america.com/elastomer_couplings/torque-limiting-coupling-esL-t.php
Filed Under: Couplings, MECHANICAL POWER TRANSMISSION
