The Ashcroft A-Series miniature pressure switch is now available in a SIL capable explosion- proof configuration for hazardous areas. With 316 stainless steel construction, an IP67 rated enclosure and an operating temperature range from -40°C to 89°C (-40°F to 192°F), the rugged dual-seal rated A-Series explosion-proof pressure switch stands up to the most extreme environmental conditions. Agency approvals and certifications include FM, UL, ATEX, IECEx, CSA, CRN, CE, RoHS as well as SIL 3 capability. Pressure ranges from vacuum through 7500 psi are offered along with a broad selection of pressure inlet fittings.
Ashcroft
www.ashcroft.com
Filed Under: Pneumatic Tips
