    • Subscribe!
Compact wireless gateway Matrix-750 for remote operations
By PR Editor | March 28, 2019
The compact Wireless Gateway Matrix-750 makes it easier for process industry customers with remote operations to set up and run wireless networks. Remote operations often have challenges with difficult installations, high expense and insufficient field personnel to keep pace with aggressive schedules. As a result, they are constantly one step behind – juggling equipment, crews, schedules and data, with limited insight into what is really needed where.
The compact wireless gateway Matrix-750 is a simple, cost-effective remote monitoring solution with device-to-cloud service with longer range, better signal coverage, improved data transmission, and rapid deployment for optimal performance and ease of use at reduced cost. It can also be used for monitoring equipment status in applications involving AGV, rail transit, port or mining area.
The compact wireless gateway Matrix-750 was meets the needs of smaller networks required for remote applications, the smaller size and DIN Rail mount capability means the Matrix-750 is suitable for the limited cabinet space requirements of most remote operations. Built-in layered security functionality ensures that the network stays protected at all times. Additional devices can be added quickly and easily without the need to configure the communication paths.
Artila
www.artila.com
Filed Under: IoT • IIoT • internet of things • Industry 4.0
Tagged With: artila
Softing introduces OPC UA-based OT/IT integration solution with MQTT connection
RF 2.0 helps engineers with radio frequency and antenna design projects
Joint consortium standardizes common “Power Consumption Management” for the shop floor
Advantech, Hivecell partnership accelerates Edge-as-a-Service for scalable AIoT
    • Subscribe!
