    • On the Floor
Component carriers simplify the mounting of sensors
By News Staff | April 26, 2021
HARTING has developed a component carrier that can be mounted directly with electronic components allowing previous manual assembly processes to be automated. Flexible circuit boards can also be replaced, increasing precision and reducing assembly costs.
With the component carrier from HARTING, the manual mounting of position sensors is no longer necessary. The component carrier increases reproducibility and reduces processing costs.
The component carrier serves as a connecting element between a printed circuit board (PCB) and electronic components (such as LEDs, ICs, photo–diodes or sensors).
Two-channel Hall-effect encoder for recording the rotation of a motor shaft.
Automatic mounting of position sensors
In electrical drives, Hall sensors are used to determine the exact position of the rotor and the electronic components are normally attached manually as wired THT components. A mechanical bracket is also mounted which aligns the sensors at an angle of precisely 90 degrees.
Such manual assemblies are no longer necessary when HARTING’s component carriers are used because the sensors are automatically mounted onto the component carrier, making an additional component for arranging and aligning the sensors unnecessary.
Component carrier solution & traditional solution.
The component carrier with the position sensors is delivered by HARTING in a blister belt packaging (tape & reel) for the automatic SMD assembly process. This component carrier replaces the manual processing steps – thus increasing the reproducibility and reducing the processing costs.
HARTING 3D-MID
www.harting.com
Filed Under: Connectors (electrical) • crimp technologies
Tagged With: Harting Inc.
  • Tech Toolbox: Decentralizing motion control with edge devices
  • Industrial automation at the extremes: aircraft carriers, and donuts
    • On the Floor
