Are aggressive fluids, extreme pressures and temperatures encountered in your applications? Is metal or stiff plastic tubing being used? For reliable air tight connections designers benefit from Beswick’s corrosion resistant stainless steel and brass compression fittings.
Assemblies are leak free due to the internal ferrules and an O-ring face seal design. Contact Beswick now for the new compression fitting for use with 4mm tubing and ¼-28 threads. M3, M4, 10-32, M5, ¼-20, and 5/16-24 thread sizes and 1/16”, 1/8”, ¼” OD tubing options are also available.
Beswick
www.beswick.com
Filed Under: Pneumatic Tips
