    • Subscribe!
Comtrol Unveils New Serial Device Servers
By Design World Staff | December 11, 2008
MINNEAPOLIS, MN ‚— Comtrol Corporation introduces the DeviceMaster‚®RTS 2-Port 1E and 2E serial device servers. Used to network-enable two serial devices on any Ethernet network, the servers come with a combination of features not necessarily offered by the competition.
DeviceMaster RTS 2-Port 1E                     DeviceMaster RTS 2-Port 2E
The DeviceMaster RTS 2-Port offers a combination of two serial ports with screw terminal connectors, dual Ethernet ports, edge-mount DIN-rail housing, and an extended temperature range, which makes the product ideally suited to industrial communication, material handling, and traffic transportation applications.
DeviceMaster RTS 2-Port 1E and 2E serial device servers offer a unique mix of value-added features, including:
* DIN-rail mounting for convenient installation;
* Wide DC voltage ranges (5‚–30 volts), which ensure the product operates in a variety of
environments;
* Wide operating temperature ranges (-37‚º‚–74‚º C), which ensure the product works well in
challenging and varied physical environments; and
* 2 Ethernet ports on the 2E so customers can daisy-chain devices together for a cleaner layout, a
faster installation and a more cost-effective solution because there‚’s no need for multiple Ethernet
switches.
www.comtrol.com
Filed Under: Networks • connectivity • fieldbuses
Softing introduces OPC UA-based OT/IT integration solution with MQTT connection
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
    • Subscribe!
