    • On the Floor
  • Advertisers
    • PR Submissions
    • Eblast Submissions
Congratulations to the 2026 LEAP Awards winners for Advanced Materials
By Rachael Pasini | October 29, 2026
The annual LEAP Awards recognizes and celebrates innovative products and technologies in engineering. Here are the 2026 LEAP Awards Winners in the Advanced Materials category.
Gold
Maxterial
MaxShield
The judges commented: “Being able to solve the hexavalent chromium application gap has been around for too long. This product fills that gap.” Congratulations!
The H-Max version of MaxShield is an electroplated nickel-molybdenum alloy coating engineered for severe wear environments under both high- and low-corrosion conditions. MaxShield is deposited using a conventional DC electroplating process, enabling rapid adoption by existing plating facilities with relatively low capital investment. It is designed to replace hard chrome coatings produced from hexavalent chromium — the cancer-causing, heavily regulated “Erin Brockovich chemistry” that has been widely used for decades in hydraulic cylinders and many other high-wear applications. Unlike hard chrome, MaxShield is free of hexavalent chromium, PFAS, lead, cadmium, and other substances of very high concern (SVHCs), while delivering superior performance and improved safety.
Compared with hard chrome, MaxShield provides 2–100× greater wear resistance, requires 3–5× less energy to manufacture, and can be deposited up to 2× faster. Compared with alternative hard chrome replacement technologies, it offers 2–20× lower cost, can be applied to complex non-line-of-sight geometries, provides exceptional adhesion, and requires relatively low capital investment for adoption.
MaxShield is not simply a hard chrome replacement. It is a surface engineering platform capable of replacing selected nickel alloys, thermal spray coatings, and weld overlays while enabling lower-cost engineering materials, such as carbon steel, to achieve performance approaching that of premium corrosion-resistant alloys, including Hastelloy, in demanding environments. MaxShield also provides tunable electrical conductivity and reduced magnetic properties, making it a promising candidate for communications, electronics, semiconductor nozzles, defense, rolls, molds, battery production, and other demanding applications where conventional coatings are limited by thickness control, corrosion performance, or accessibility.
Silver
TE Connectivity
Aluminum MAG-MATE IDC Solution for Next-Generation Motor Applications
As rising metal material costs and growing demands for lightweight design reshape the motor industry, aluminum magnet wire has emerged as a compelling alternative to copper — delivering equivalent performance at reduced cost and weight. TE Connectivity has responded with an innovative, fully integrated aluminum IDC connection solution that addresses the critical reliability challenges of aluminum wire systems.
At the core of this solution is the MAG-MATE terminal with IDC (Insulation Displacement Connection) technology, which establishes a direct, airtight connection with magnet wire — eliminating the need for insulation pre-stripping. The precision IDC structure punctures and displaces the insulation cleanly, protecting the internal conductor and ensuring consistent, reliable electrical contact.
To overcome the electrochemical corrosion risk inherent in dissimilar metal connections, TE developed dedicated aluminum terminals that achieve full material compatibility with aluminum magnet wire. Combined with a BMC (Bulk Molding Compound) encapsulation that seals the connection from air and moisture, the solution effectively eliminates oxidation risks, ensuring stable long-term motor performance.
This total solderless solution delivers measurable customer value:
  • ~38% cost reduction versus conventional brass terminals
  • Significant weight savings aligned with lightweighting trends
  • Higher automation compatibility, improving throughput and reducing manufacturing costs
  • Elimination of soldering — removing environmental hazards and quality variability
Applicable to fan motors, HVAC systems, and compact motor platforms, this solution exemplifies TE’s commitment to innovation, sustainability, and customer-driven engineering excellence.
Bronze
Supersede
Supersede Marine Board
Marine-grade plywood has been the structural default in boatbuilding for decades, but its failure modes are well-documented: moisture absorption, rot, warping, toxic chemical treatments, and natural variation that forces engineers to design to conservative tolerances rather than actual performance. Supersede Marine Board eliminates that.
Engineered from extruded post-industrial recycled polypropylene, Marine Board is a true 1:1 structural replacement for marine-grade plywood, matching standard geometry and thickness exactly while outperforming it in compressive strength, fastener retention, bending stiffness, and dimensional stability. It achieves zero water absorption, zero swelling, and complete resistance to rot, mold, and termites, with no formaldehyde or CCAs. Ideal applications include flooring, kickboards, transom boards, bulkheads, stringers, and hull liners in production boatbuilding, with parallel deployment in RV, specialty vehicles, and modular construction.
Development required three years of stealth R&D, including a comprehensive benchmark catalog physically testing every major marine board on the market, iterative FEA simulation, proprietary additive development to normalize recycled feedstock variability, and trial builds with production manufacturers before commercial commitment. Supersede was granted a utility patent. Thunder Jet adopted Marine Board across its entire 2026 model year lineup.
The extrusion process enables control over density, geometry, and surface finish, producing dimensionally consistent panels. Engineers can specify with confidence, tighten tolerances, and reduce safety margins that exist only to account for wood’s natural variation. It installs with existing tools and methods, requiring no sanding, sealing, or drying.
Offcuts and end-of-life material are recovered through Supersede’s buyback program and re-extruded into new product, closing the loop entirely.
For the complete list of 2026 LEAP Awards Winners, visit designworldonline.com/2026-leap-awards-winners-are-announced.
Filed Under: LEAP Awards, Materials • advanced
Tagged With: TEConnectivity, supersede, maxterial
Rachael Pasini
Rachael Pasini is the editor-in-chief of Design World, covering industrial automation technologies, advanced materials, fluid power, additive manufacturing, and more. She also supports engineering leaders and managers in developing and sustaining innovative teams. Rachael holds a master’s degree in civil and environmental engineering and a bachelor’s degree in industrial and systems engineering from The Ohio State University. With nearly two decades of technical writing experience, along with trade journalism and teaching college math and physics, she is passionate about educating individuals and building supportive engineering communities.
  • Big growth in U.S. industrial automation
  • Siemens aims for 80 percent automation in German plant
  • Humanoids building humanoids, and new robots for agriculture equipment in Kansas
  • Amazon takes on another industry: robotics
    • On the Floor
  • Advertisers
    • PR Submissions
