connectBlue Presents a Bluetooth Dual-Mode System-on-Module
By atesmeh | May 2, 2014
Thanks to its powerful microcontroller (MCU), the new Bluetooth Dual-mode System-on-Module OBP421 can eliminate the need for a double set of MCUs. The OBP421 thus offers a more compact design than a traditional system where the customer application is separated from the wireless module. This possibility becomes particularly beneficial in physically constraining applications where Bluetooth dual-mode capability, quick time-to-market and cost efficiency are important. Photo Credit: connectBlueconnectBlue has launched the System-on-Module OBP421 which is a Bluetooth Dual-mode (Bluetooth Smart Ready) module. The System-on-Module OBP421 is a compact and fully customizable module particularly suitable in industrial, medical, and Internet of Things (IoT) applications where Bluetooth dual-mode capability, quick time-to-market, and cost efficiency are of key importance.
With the Bluetooth Dual-mode System-on-Module OBP421, it is possible to get full control of all system resources in one compact solution. Since the OBP421 is Bluetooth Smart Ready, it will become possible to create, compile and link real C code embedded applications with the ability to access any connected Bluetooth Smart sensor using the Generic Attribute Profile (GATT). Examples of customer specific embedded application software written in C include protocol conversion, data logging, scaling and filtering of digital & analog I/O signals, HMI functionality, CAN-bus connectivity, and intelligent (I2C / SPI) sensor connectivity.
The OBP421 is based on the standard Bluetooth Serial Port Module OBS421 which has already been proven in use in demanding applications. Recently, the OBS421 was equipped with an even more powerful microcontroller unit (MCU) which laid the foundation for the OBP421 launch. This ARMCortex-M3 32-bit RISC core operates at a 72 MHz frequency with high-speed embedded memories consisting of Flash memory up to 384 kB and SRAM up to 64 kB. The microcontroller offers an extensive range of enhanced I/Os, peripherals, 12-bit ADCs, general-purpose 16-bit timers, PWM timers, as well as standard and advanced communication interfaces like I2C, SPI, USART, and CAN.
“Thanks to the powerful microcontroller, the OBP421 module can even be used as a complete host CPU replacement,” says Rolf Nilsson, CEO of connectBlue. “The customer can thus use our OBP421 for the entire system needs benefitting from the design, testing, and type approvals already implemented in the OBP421. Thereby, the customer gets a compact system design on a proven hardware with full application flexibility gaining greatly on time-to-market and cost efficiency.”
Customers that have already purchased the Bluetooth Serial Port Module OBS421 can get the Bluetooth System-on-module OBP421 functionality by purchasing a Starter Kit for the application software implementation and sign a royalty-free software licensing agreement.
The Bluetooth Dual-mode System-on-Module OBP421 is a Bluetooth v4.0 module with 300 meters wireless range, GATT support for Bluetooth Smart, Android support and iOS support (Bluetooth low energy only). Each module is individually tested during production and the OBP421 is radio type approved for USA (FCC Part 15), Europe (ETSI R&TTE), Japan (MIC – formerly TELEC) and Canada (IC RSS). The OBP421 is also compliant with EMC, Safety and Medical standards, and Bluetooth qualified. Further, the module has an embedded Bluetooth dual-mode stack (SPP, DUN profiles and connectBlue Low Energy Serial Port Service) as well as a temperature range of -30 to +85°C.
For more information, visit www.connectblue.com.
