Connectivity Options for Motor Protection
By Design World Staff | April 17, 2012
The C441 Ethernet series of communications cards let you select from Ethernet/IP, Modbus TCP, HTTP web services and Modbus RTU communication protocols within one card. These cards are compatible with Eaton C440, XTOE and C441 electronic motor protection relays, S611 soft starters, and can be used as stand-alone input/output (IO).
Integral web services provide web-based graphical user interface (GUI). With four levels of access, the cards ensure only those with credentials have access to critical or sensitive functions. With a dual port switch, the Ethernet card allows easy daisy chaining and reliable ring configurations. Additionally, you have the ability to use one network for control and another for monitoring – through the Modbus serial protocol used in parallel with the Ethernet network –allowing redundant communications and greater reliability with a single card.
Eaton Corporation
www.eaton.com
Filed Under: Ethernet — cables • hubs • switches, CONNECTIVITY • fieldbuses • networks • gateways
