Conserve compressed air for manufacturing applications
By Lisa Eitel | February 18, 2021
Compressed air is a limited resource that is generated in-house for the benefit of many operations within the manufacturing environment. Learn how to ensure all point of use applications are using your compressed air in the most effective and efficient way possible.
white paper
If an open, unchecked water pipe was being used to cool a machining process, the excessive volume of liquid being used would be obvious to see as it pooled on the floor. It would be clear that you would want to test lower flow rates that would conserve water and save money yet still effectively cool the part. But if an open compressed air line was being used to perform the same process, it would be much more difficult to envision the large volume of compressed air that could be wasted while trying to cool the same part.
Since compressed air generation is every bit as important to most factories as a supply of water, it only makes sense to consider ways to conserve it and reduce its expense. Learn how much it costs to produce that compressed air. Register and download the white paper, Compressed Air Open Blowing, to learn the options available for reducing compressed air waste while still delivering the desired performance. For more information visit, exair.com.
Filed Under: MANUFACTURING
Tagged With: exair
Lisa Eitel
